Sharky81's avatar
Sharky81
Novice
May 12, 2016
WNDR4000 N750 VDSL Support
Hello,
I´m from German and want change my internetprovider. I have a WNDR4000 WIFI router. And my question is,
supports my router annex-j and the standard 1TR112 protocol for using VDSL from Telekom and IP phoning?
Thanks for your answers...
Best regards
Heiko M.
  • Hello Sharky81
    Welcome to the community!
    Our routers will work with your modem as long as it support the protocols you mentioned.
    Now, if you decided to get one of our VDSL gateways all mentioned protocols are supported.
    Should you need to check our VDSL gateways see here.
1 Reply
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello Sharky81
