cwcarlson
Dec 29, 2015Aspirant
WNDR4300 Attached devices
I'm very happy with the WNDR4300 (N750) router, especially after suffering through competitors' routers. I'm curious about the Attached devices listing showing <unknown> for the IP address provid...
- Jan 04, 2016
Welcome to the community, Chris!
It looks like a firmware problem.
Did you try to do a factory reset?
How about reflashing the firmware of the router?
If you have not updated the firmware yet, kindly do so and then reset the router.
However, if you have the latest firmware installed, reflash it by loading the latest firmware again and then reset.
After factory reset, reconfigure the router to get the connection back and see if it corrected the problem.
cwcarlson
Jan 10, 2016Aspirant
The firmware was already up to date, but I re-installed it anyway. Seems to have fixed it. Thanks.
Retired_Member
Jan 11, 2016Don't be surprised if they show up unknown again, many of the NG routers have similar problems. Try using address reservations.
