psky's avatar
psky
WNDR4300 Connection is not private, certificate authority invalid
When we try to connect to the internet with our cells, tablet, laptop, we get;
"Your connection is not private", NET::ERR_CERT_AUTHORITY_INVALID.
Called my internet provider who troubleshooted over the phone, then sent a tech out. After troubleshooting, tech says its strange that 2 MAC addresses come back whenever I try connecting just one device, when only one address should be coming back. Tech said the router is bad and needs replaced. The router is only 4 months old. Anyone heard of this issue?
  • Factory reset worked! You saved me from having to buy a new router, thanks.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, psky
    Did you try using a different browser?
    Which browser are you using?
    Have you also tried doing a factory reset on the router?
    After resetting the router, reconfigure it as if it's brand new out of the box then check for your connection.
    • ElaineM's avatar
      ElaineM
      You're welcome. Glad to hear that it's up and running!
      Have a great day!
