Fluid
Sep 26, 2016Aspirant
WNDR4300 Dos Attacks
In my logs I see [DoS Attack: Ascend Kill] from source: 85.252.162.7, port 123, Monday, September 26, 2016 17:57:50 [DoS Attack: Ascend Kill] from source: 195.154.174.209, port 123, Monday, Septemb...
- Sep 29, 2016
Thank you.
So you are saying these things are normal. Ok, I dont have a slow network, so I guess I can stop worrying :)
ElaineM
Sep 28, 2016NETGEAR Employee Retired
Hello Fluid
Welcome to the community!
The router just basically shows you these logs for information.
It's an alert that tells you that someone tries to knock and check if they can open the door.
Are you having slow down performance in your network?
If you do, it's best to coordinate with your ISP and check if they can give you a new IP address.
