ebgreene_89
Mar 20, 2019Aspirant
wndr4300 firmware update not working
I received an email from NETGEAR regarding an update to my WNDR4300 firmware. As it was uploading I got this message, and could go no further:
"Secure Connection Failed
An error occurred during a connection to www.routerlogin.net. You have received an invalid certificate. Please contact the server administrator or email correspondent and give them the following information: Your certificate contains the same serial number as another certificate issued by the certificate authority. Please get a new certificate containing a unique serial number. Error code: SEC_ERROR_REUSED_ISSUER_AND_SERIAL."
Anybody know what to do? I have never had this issue before in uploading firmware updates to this router.
Hi ebgreene_89,
You can try using another browser or device and see if the issue will persist. Also, make sure that the time setting on the device your using to upload the firmware is correct (same with the router).
Dexter
- DexterJBNETGEAR Moderator
Hi ebgreene_89,
Dexter
- ebgreene_89Aspirant
Thank! It appears to have uploaded.
