db3's avatar
db3
wndr4300 no wireless in linux mint
i just installed linux mint on my thinkpad laptop & discovered I have no internet unless I plug in the cable.
I also have win7 on it & it will work wireless, no cable.
Anyone know the routine for getting it to work wireless in linux mint? or does it not do that.
  • db3's avatar
    db3
    Feb 22, 2016
    using mint 17.3 cinnamon.
    it started working.
    i think it takes a bit longer to establish conn than cable.
  • Retired_Member's avatar
    Retired_Member
    missing mint drivers for wifi card?
    • db3's avatar
      db3
      i suspect missing drivers is the case but so far no luck finding them
      i'd be interested to know if the combo of lenovo thinkpad + netgear +linux is a nogo as far as wireless is comcerned.
      I'm beginning tio get that impression.
        Retired_Member
        The problem isn't netgear (this time) you should take this up with your wifi card manufacture. Before changing OS it's a good idea to be sure your hardware is supported by checking for drivers.
        Good Luck!
