srsbsns
Apr 03, 2015Aspirant
WNDR4300v2 and Chromecast
Anyone else having issues with Chomecast and the v2 version of this router? All Chromecast compatible apps are missing the cast button until I reboot the Chromecast. It stays functional for about 5 m...
- Nov 08, 2015
@minions08 wrote:
Chromecast are the one releasing list of devices which are compatible with their device. So far it is still not compatible with WNDR4300v2.This information is incorrect. Not to be that guy if you are going to give users misleading information on the forums please attempt to back it up.
Now onto the problem. I did a Wireshark trace and I noticed the router is not transmitting the multicast packets sent by the chromecast. This problem is entirely on Netgear and so far they have neglected this router. Its been out for almost a year and is still on its inital firmware release that contains vulnerabilites. To top that off my Nest doesnt work correctly with this router as well. the heartbeats are not making it to Nest servers and its contantly offline but is pingable from inside the network. Netgear is just passing the buck onto Nest.
I have been able to fix the Chromecast issue by tinkering on my own.apply the following setting. FIX: Uncheck "disable IGMP Proxy".
Netgear support was never able to fix this and the supposed engineers offered zero solutions. I dont think I'll ever buy another Netgear product again based off what I experienced with this company. The hours of phone calls and promises to contact me that were never met... I do hope the fix that I found works for the unfortunate people like myself who purchased this router.
srsbsns
Nov 08, 2015Aspirant
ElaineM
Nov 10, 2015NETGEAR Employee Retired
srsbsns I apologize for any inconvenience this may have caused you.
We at NETGEAR strive to provide the best service possible for our customers.
For the vulnerability, here's a link of our statement when it comes to the ReadySHARE vulnerability.
Regarding the Nest, which Nest device do you have?
How is the Nest connected to the router? Wired or wireless? Which signal you're connecting it to (2.4Ghz or 5Ghz)?
Again, I apologize for any inconvenience.
- srsbsnsNov 12, 2015Aspirant
ElaineM wrote:srsbsns I apologize for any inconvenience this may have caused you.
How is the Nest connected to the router? Wired or wireless? Which signal you're connecting it to (2.4Ghz or 5Ghz)?Again, I apologize for any inconvenience.
Elaine ,
Thank you for the post. Netgear has released a firmware 1.0.0.32 that resolved the security vulernabilites and Chromecast/Nest issues. Can you explain why the link you provided for the ReadySHARE vulnerability says there is no problem with the WNDR4300v2 and no fix is needed yet 2 days ago Netgear posts firmware with a changelog that contains the following bug fix notes? That link has been provided anyone asking about the vulnerabilities saying there is no problem. One could conclude users have been mislead until now. I know you are providing what information you have but somebody has not been telling the whole truth at Netgear.
Bug Fixes
- Fixes the SOAP security issue.
- Fixes the KCode NetUSB security vulnerability issue
- ElaineMNov 16, 2015NETGEAR Employee Retired
- GeorgeBittNov 28, 2015Aspirant
I installed the latest firmware and the chromecasts still didn't work.
I did the IGMP change and the chromecasts did work at that point, but it means I have to use my device as a router when I was wanting to use it as an access point. So no my wired devices that aren't connected to the WNDR can't see the Chromecasts. Is the nest working yet? I was hoping to pick one up but it sounds like that doesn't work with this device either so I'll probably need to replace this router.
- ElaineMDec 10, 2015NETGEAR Employee Retired
srsbsns Our engineering team has confirmed that the updates to WNDR4300v2 firmware was not to fix any issue with NetUSB vulnerability, but to provide an enhancement to the router to avoid vulnerability. The release notes have been updated to reflect this change more accurately.
Thank you for posting in the Community.
