Digitdave
Mar 05, 2017Aspirant
WNDR4500 repeater setup mistake, now can not login to router
I tried to set up a repeater Wifi connection from my phones Hotspot to router WNDR4500. (There is limited help instructions for setting up repeater so not supprised I messed it up) Using the 5ghz W...
- Mar 05, 2017
Push the reset button for about 8 to 10 seconds until the lights flash off and on.
Digitdave
Thanks, I managed to get to reset after searching for topic, reset to factory defaults, I must have not been holding the reset button long enough!
