nougain
Jan 24, 2015Aspirant
WNDR4500 Stopped Working | Power Blinking Green, Internet Solid Amber
My WNDR4500 Stopped Working for past few weeks. Power LED is Blinking Green and Internet LED is Solid Amber. All other LEDs are dead (2.4 GHz Wifi, 5 GHz Wifi, USB1 and USB2). Ethernet LED glows thoug...
- Feb 20, 2015Try this link to recover the firmware of the router.
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the-setup-cd-recovery-tool
nougain
Have you first of all just tried a factory reset of the router?
YES
In the instructions for firmware recovery did you set a static IP at the computer, and is the computer directly connected to the router?
COMPUTER IS DIRECTLY CONNECTED WITH THE ROUTER USING A LAN WIRE. I CAN SEE THE CORRESPONDING LED GLOWING. PERHAPS I DON'T KNOW HOW TO SET STATIC IP PART. I TRIED THIS..https://www.dropbox.com/s/7h7yiaa3ze4h1cf/StaticIP.jpg
I suggest that when you do this you disconnect the router from the modem or any other network devices other than the computer.
ALL NETWORK DEVICES CONNECTIONS, MODEM, USBs ARE DISCONNECTED.
Is the router still within its warranty period?
NO
YES
NO
