SailorAspie19's avatar
Oct 19, 2023
WNDR4500 unable to connect to wifi
I have an iPhone with iOS 16.6.1. I've tried to connect to my WNDR4500 router wirelessly, but I got an error message saying "unable to connect to the network", even though I had the correct passkey. The problem seemed to temporarily go away when I turned the router off for a few minutes and on again. Is there a problem with the router?
Firmware Version
V1.0.1.46_1.0.76
  • I think your iOS is too new for the router or your router is too old for your phone.
  • plemans's avatar
    1. what modem/gateway do you have?
    2. what firmware is on the router?
    • SailorAspie19's avatar
      SailorAspie19
      I have a frontier modem and the firmware is mentioned in the first post
      • michaelkenward's avatar
        michaelkenward
        Sadly, that just reduces the search to maybe a dozen or so devices that Frontier has supplied over the years, rather than hundreds of possibilities.
        frontier modem - Google Search
        Most of these things have a label on with the make and model number.
        What are they?
        Did you check the iOS advice?
    michaelkenward
    What makes you think that the router is the issue?
    Try this:
    NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
    By the way, the WNDR4500 dates back to 2013 and is several generations behind current wifi technology.
