mystic1287's avatar
mystic1287
Wndr4500v2- New firmware causing performance issues?
So, I applied the latest firwware update- V1.0.0.62_1.0.39 2 days ago and now my router is performing poorly. On a hard line it takes 20-30 secs to load the admin page. Has anyone else experienced this?
  • Did you perform a factory reset after applying the new firmware?
    That is the first thing to try if you have "post-flash" problems.
  • michaelkenward's avatar
    michaelkenward
    • mystic1287's avatar
      mystic1287
      No, but I did re-apply the FW upgrade, back to SNAFU.....rocking!
        michaelkenward
        Well done.
        Reset isn't always needed, but it is worth trying if something seems wonky.
