Bengt7jqb
Oct 20, 2017Aspirant
WNDR4500v2 E-Mail port number
How can I define the port number? Cant find a spot to use here
- Nov 08, 2017
The model has been considered EOL for awhile now and there will be no future firmware enhancements that will be released.
michaelkenward
Oct 21, 2017Guru - Experienced User
What are you trying to do? Set up email alerts?
There is a manual for the WNDR4500v2 somewhere at the end of this link:
>>> WNDR4500v2 | Product | Support | NETGEAR <<<
See page 74.
Bengt7jqb
Oct 21, 2017Aspirant
I need to specify port number too, 587 for this one
Is it posible? Or it comes in next update?
- michaelkenwardOct 21, 2017Guru - Experienced User
If it isn't available already, that isn't the sort of thing that new firmware is likely to add.
On my device it is in:
- Advanced
- Security
- Bengt7jqbOct 21, 2017Aspirant
But there are no space for port number
- antinodeOct 21, 2017Guru
> Can't (yet) see the picture. A plain-text description might appear
> sooner.
Still true.
Huh? Is there a place to put the Mail Server name/address? Can you
add ":587" to what you have there now? It's not complicated.
sooner.
I know nothing about these routers' e-mail capabilities, but a
standard notation would be "<name_or_address>:<port>". Adding ":587" to
the Mail Server name/address should be an easy experiment to run.
