Barry_Colson
Jul 27, 2018Aspirant
WNDR4500v2 firmware update failed
Installed update and waited for counter to stop. Could not get a connection. Saw light on router blinking, turned off router, waited 30 seconds then turned router back on. Tried to connect to internet but could not. Reset router to factory default but still could not connect to the internet. Connection attempts to the router failed. Anyone know what my next step would be?
Sound advice from wcalifas831. Here is Netgear's take on it.
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
That is a bit out of date in that it does not tell you that Windows has a TFTP function built in, you just have to enable it.- Control Panel
- Programs and Features
- Turn Windows features on or off
- TFTP client - enable
That's probably easier than retrieving software from a website.
TFTP is a "command line" utility. In Windows it runs from a Command Prompt window. Get there with Winkey + R and enter cmd.To write the firmware to the device you need to type in:
TFTP -i 192.168.1.1 put {firmware}
where {firmware} is the name of the firmware file you retrieved.
Put the firmware in a directory you can get at, and run TFTP from there.
What does the power LED look like?
- wcalifas831Prodigy
Is the bliinking light just the power light blinking? I've unbricked my wndr4500 before using the tftp method. Look on youtube and follow the steps on "how to debrick a router" You'll have to download a program to your computer called tftp2. You'll have to change a few setings on the ethernet adapter (Ip settings) which those videos will show. You'll also need to download whatever firmware you want to load on it from the netgear website under the support section for your specific model.
