phmketih's avatar
phmketih
Follower
Dec 22, 2015
WNDR4500v3 not running in 802.11n mode
Hello,    I have a Netgear WNDR4500v3 (N900) router and I've noticed that I'm actually running in my 2.4ghz band in 802.11g and my 5ghz band(which I use exclusively for gaming devices) is running i...
  • Retired_Member's avatar
    Retired_Member
    Dec 22, 2015
    WPA2 security is required for N check to be sure you're using it. Also WMM needs to be enabled too.
