klamation
Dec 01, 2015Aspirant
WNDRMAC router no longer connects on 2.4Ghz network
I'm probably grasping at straws here, but does anyone have any ideas for a WNDRMAC router that is missing its 2.4GHz network? It was working fine just a few days ago, and then none of my devices can...
- Dec 04, 2015
Hi ElaineM, thanks for the links. I downloaded and re-installed the firmware, and the 2.4GHz network still does not show up. I even went into the Advanced Setup > Wireless Settings, and tried disabling both the 2.4GHz and 5GHz Wireless Router Radios, and notice the 5GHz is still broadcasting its SSID, so I disabled both SSIDs, then re-enabled the radios and SSIDs. No luck in this.
The strange thing is, the router thinks the wireless is working properly. So, the problem really is faulty hardware. I guess I'm out of luck?
ElaineM
Dec 02, 2015NETGEAR Employee Retired
Do you still have the wireless LED on?
Did try to re-flash the firmware of the router?
- klamationDec 02, 2015Aspirant
Hi ElianeM! Thanks for your response and, valid questions. Yes, the Wireless LED, the little icon that looks like ((o)) is on, glowing blue. The 5GHz network is visible, but the regular one is not.
I have not tried re-flashing the firmware. It's a valid suggestion, but currently the downloadcenter.netgear.com site is offline. The most I have tried to do is reset the router to factory defaults, and have played around with some of the wireless settings, but it doesn't seem to make a difference.
- ElaineMDec 02, 2015NETGEAR Employee Retired
It can be considered faulty hardware if re-flashing did not work.
Normally, factory reset should correct this but then just to exhaust all possible solution hence, I suggested firmware re-flash.
If you happen to have version 1, click here.
For version 2, see this page.
- klamationDec 04, 2015Aspirant
