klamation
Dec 01, 2015Aspirant
WNDRMAC router no longer connects on 2.4Ghz network
I'm probably grasping at straws here, but does anyone have any ideas for a WNDRMAC router that is missing its 2.4GHz network? It was working fine just a few days ago, and then none of my devices can...
- Dec 04, 2015
Hi ElaineM, thanks for the links. I downloaded and re-installed the firmware, and the 2.4GHz network still does not show up. I even went into the Advanced Setup > Wireless Settings, and tried disabling both the 2.4GHz and 5GHz Wireless Router Radios, and notice the 5GHz is still broadcasting its SSID, so I disabled both SSIDs, then re-enabled the radios and SSIDs. No luck in this.
The strange thing is, the router thinks the wireless is working properly. So, the problem really is faulty hardware. I guess I'm out of luck?
ElaineM
Dec 02, 2015NETGEAR Employee Retired
It can be considered faulty hardware if re-flashing did not work.
Normally, factory reset should correct this but then just to exhaust all possible solution hence, I suggested firmware re-flash.
If you happen to have version 1, click here.
For version 2, see this page.
klamation
Dec 04, 2015Aspirant
