Joesoto125's avatar
Joesoto125
Wnr1000v4. Security wall
I use this router at my job as my own personal router. I connect it to the company network. Many other employees do the same because it is allowed my job. I keep getting a security wall message when I go to certain websites. I had a different router at one time and I never encountered this problem. None of my other co-workers have this problem. Is there a special setting that I need to change in order to fix this problem? If so, please help
  • Thanks for the ideas guys but still no help. IT and human resources has nothing to do with it because everyone elses router is working fine. Unfortunately I'll have to switch to another brand of router all together. The first one I had was Belkin and it worked fine b
  • Anonymous's avatar
    Anonymous
    Contact your Human Resources Dept. I bet they have a solution for this problem.
  • It has to do with a specific setting in the router. I can't find the way to do it though. Would appreciate advice from anyone with a suggestion
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Joesoto125 You may also try to reach out to your IT department for further help.
