CDFree's avatar
CDFree
WNR2000 v4 does not allow any devices to connect
So, my old router was somehow 'defective'. I received a new onw in the mail and have hooked it up, installed new firmware and am able to access the internet on my desktop, but that is the only device...
  • Retired_Member's avatar
    Retired_Member
    Feb 11, 2016
    I would factory reset default and use the default settings.
    I would forget about static IP's and MAKE sure each device is set to DHCP
    I would forget all previous connections in each device.
    I would read manual regarding trouble shooting
