nkravit
Jun 02, 2018Aspirant
WNR2000v-3 Router
I just rebooted my router and lost my connection to a Roku device. My cell phone won't connect any longer either. So I think the whole Wifi network is off. I set it up long ago enough that I don't remember all the things I did. I remember it as not being terribly difficult. I can't figure out how to get it working again. I set up another network for my husband and his restart didn't disconnect any of his wireless devices. Can anyone help? The home router is a model WMR2000v3.
I tried again after several hours and surprise! It connected. Earlier, I was getting messages from my devices that no internet connection was detected. I have no idea what changed, but it didn't appear to be anything I did. So I've now connected the internet with my streaming device and with my cell phone. I'm very relieved. Thanks to michaelkenward for trying to help.
Are the wifi LEDs lit on the device?
Do you have wired devices that can connect? Or is the whole Internet down?
- nkravitAspirant
- nkravitAspirant
Yes I did have wired devices that could connect. But it turned out that the solution was very simple. I waited (partly out of frustration I turned to doing something else) and after an hour or so the system had found my wireless signal and I was able to complete the set-up. Thank you so much for responding!
