bmm6o
Dec 29, 2018Aspirant
WNR2000v5 Slow download speeds
WNR2000v5, Firmware Version V1.0.0.70
I've been trying to improve my download speeds. I ran some experiments using speedtest.net.
Case 1: Laptop right next to wifi router. Speeds: 52 Mbps down,...
- Dec 30, 2018
According to Netgear's manual for the WNR2000v5 the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.
That explains this bit:
bmm6o wrote:
What could account for the large speed difference between the two wired setups?Everything else follows on from that. Your router is not up to the job.
michaelkenward
Dec 30, 2018Guru - Experienced User
bmm6o
Dec 30, 2018Aspirant
Thanks for pointing that out. I understand that I can't get the full 119 through the router, but shoudn't i get closer to 100 than the 70 I'm seeing? And what can I do to get the wireless rate to be closer to the wired rate? I would hope it's possible to get more than half the rated limit. I don't think it's due to contention on the channels, but I don't have any other ideas.
- michaelkenwardDec 31, 2018Guru - Experienced User
bmm6o wrote:
....but shoudn't i get closer to 100 than the 70 I'm seeing?
Those 100 Mbps numbers are always "up to" marketing stuff. They hide the fact that other things are going on in the background. The connection may indeed be at 100 Mbps, but there is a lot of data negotiation going on, not to mention other stuff on the network. Then there is the reliability of the speed tests.
You are on to a hiding to nothing with that router. The WNR2000v5 is a basic box that does not even support 5 GHz wifi.
Not knowing anything about the wifi clients on your network it is hard to say. But for many things 52 Mbps is not that bad, given the quality of your router. N300 is about as slow as it gets in wifi terms.
Does your laptop get significantly faster wifi speeds with different sources?
- bmm6oJan 01, 2019Aspirant
It's a good question, but I don't know the answer. I've only recently started looking at ways to improve my home network so I haven't had a chance to test individual pieces in other locations.
