evjayan
Jan 03, 2021Follower
WNR2200 Wireless repeater function
I am having both WNR2200 (purchased in 2012) and WNR 614 (purchased in 2017) model routers. Currently I am facing issues in the wifi range in my house, so decided to connect both the routers together, one will be first floor and other one will be in ground floor. Can anyone suggests best possible options to connect between them, without sacrificing wifi performance ?
Firmware version for WNR 2200 : V1.0.1.102 and for WNR614 :V1.1.0.62
I could not find any wireless repeater function in WNR2200, whereas in WNR614 it is available.
1 Reply
to not sacrifice speed? Hardwire the 2nd one in.
I'd actualy just look at upgrading the system. Both of those devices are base model 10/100mbps with wireless N300. They're slow from the start.
Unless you're on pretty slow dsl, they're poor performing routers
