Jazzsterre's avatar
Jazzsterre
WNR3500 keeps dropping the connection
Every 4 or 5 days my WNR3500L drops the internet connection and the wifi-connections. I run with firmware V1.2.2.48_35.0.55 (the latest). When I switch the power off and on again the router works a...
  • Jazzsterre's avatar
    Jazzsterre
    Apr 21, 2016
    Hi, it helped to downgrade the firmware version, as described above.
    I swithed off the settings to install the latest firmware.
