Jazzsterre
Mar 12, 2016Aspirant
WNR3500 keeps dropping the connection
Every 4 or 5 days my WNR3500L drops the internet connection and the wifi-connections. I run with firmware V1.2.2.48_35.0.55 (the latest). When I switch the power off and on again the router works a...
- Apr 21, 2016
Hi, it helped to downgrade the firmware version, as described above.
I swithed off the settings to install the latest firmware.
Jazzsterre
Apr 01, 2016Aspirant
today it went down 3 times, wired and wireless. 5 wireless devices were connected.
Jazzsterre
I cannot find the firmware for Europe, only for North Amerika. please help...
- JazzsterreApr 06, 2016Aspirant
thanks for the link. I just reflashed the router and will monitor for the next days..
- ElaineMApr 06, 2016NETGEAR Employee Retired
You're welcome. Feel free to give us an update anytime.
Hi, I reflashed the firmware yesterday, but this morning the router hung again.
Powerled is green, i-led is green, wifi is blinking blue, direct lanport is orange.
http://www.routerlogin.net. was not accessable with any system (wired and wireless)
When I recycle the power everyting works 'normal'.
- JazzsterreApr 08, 2016Aspirant
Hello, it is me again :-)
I have read your solution, but just before I down-graded the firmware version, I noticed that www.routerlogin.net was blinking on the right part of the screen. It took about 3 minutes before i could select the upgrade section.
The powerlight was continuous green.
The internet was blinking green.
The wireless was blinking blue.
The LAN-port was blinking orange.
Maybe helps this information to detect the problem of my router.
I will inform you if the firmware downgrading gives a stable situation.
- ElaineMApr 11, 2016NETGEAR Employee Retired
Jazzsterre How's the connection so far?
Is the power light continuously blinking?
- JazzsterreApr 21, 2016Aspirant
Hi, the connection is stable for over a week now.
Thank you for the support!
- ElaineMApr 21, 2016NETGEAR Employee Retired
Jazzsterre What made it work?
