sunrays
Jan 05, 2017Aspirant
WNR3500Lv2 does not switch on
Hi, I was using my Netgear router all this while without any problems. Since about a month or so, I have been using a mobile hotspot at home and hence not been using my cable boradband (and by exten...
ElaineM
Jan 06, 2017NETGEAR Employee Retired
Welcome to the community, sunrays
Try to get another working power adapter with the same power specs.
In this way, you will be able to determine if it's just a power adapter problem or the router itself.
sunrays
Jan 19, 2017Aspirant
Hi Elaine,
Thank you for the reply. Would you have any other suggestion as well for me to try, presuming there is some issue with the router itself? The reason I'm asking is that there's nothing that happened that should lead to the adapter or the router conking off. In fact it was working fine till for a month or so I stopped using WiFi at home.
- ElaineMJan 19, 2017NETGEAR Employee Retired
Try plugging it on a different power outlet.
To be honest, there's nothing much else to try.
If it still has hardware warranty then get a replacement.
