cryptoz's avatar
cryptoz
WNR3500Lv2 Open Ports
Hello, I have set up this router with wifi off, dhcp off, Upnp off and only ports 8080, 8096 forwarded to backend servers.  nmap scan shows  Discovered open port 443/tcp on 65.152.255.209 Discove...
  • cryptoz's avatar
    cryptoz
    May 15, 2018
    wow what a pain... the ports are default services in the router that are open regardless if you use the service or not and can be closed by explicitly disabling the services... Advanced Tomato is an excellent alternative to this garbage interface, and I'm sure the support is better too because the bar is pretty low
