Jayesh_P's avatar
Jayesh_P
Won't connect through the modem
I replaced a failing Xfinity router/modem with NightHawk CM1150V and AC1200 (because the local tech store was sold out of a combined unit and I really coud not wait for a week to restore wifi.)
Now that NightHawk modem connected nicely with the help of the folks at Xfinity and I hoped that the AC1200 Smart Wifi Router, also being Netgear would integrate smoothly. It does not.
The wired devices are Windows 10 and connect through the Nighthawk, are recognized with a green LED and connect to the internet just fine. When I added the AC1200 Smart Wifi Router, it also connected with a green LED and the network was accessable however internet was not accessable, even after using the 'Setup Genie'. After several resets of both modem and router, including both at the same time, I got nowhere and called tech support.
Tech support walked me through the 'Setup Wizard' on the Advanced tab of the Internet screen but were unable to get the IP address, IP subnet or Domain Name Server information to populate, with IP Address, Subnet Mask and Domain Name Sever reading 0.0.0.0 and instructing me to contact my internet service provider.
The tech support at Xfinity simply told me that the router should not need to querry the servers directly and that this should be updated from the modem.
I feel like I am chasing my tail, even after reading the user's manual.
Because I am considering taking the whole thing back and changing products, I am somewhat hesitant to try updating the firmware. Here is the system:
PCs: Windows 10 x2 wired
Wireless: Widows 10 tablet, Android phones
NightHawk CM1150v
R6220 AC1200 Smart Router running firmware V1.1.0.86_1.0.1
    This statement is whats going to make me question you. Do you have other devices connected to the cm1150v other than the router?
    If so, thats more than likely whats causing your issue. The cm1150v isn't a router. its a modem only. And the vast majority of ISP's only assign 1 public IP address. Meaning that only 1 device can be connected to the modem at a time. That 1 device can use wan port aggregation (the R6220 doesn't have this feature) to reach speeds >1gig but it can't have more than 1 device connected.
    Again, this is if your isp doesn't support more than 1 public ip address. And thats the majority of them.
    If you connected your pc to it, that public ip address is being assigned to the pc and not to the router.
    so try this.
    Disconnect all the devices from the cm1150v, power it off and the router off.
    power on the cm1150v. give it several minutes to fully boot.
    connect port 1 of the modem to the wan port of the r6220
    power on the router. give it several minutes to fully boot.
    try to setup/us the router.
  • When you run the setup genie is that through your cell phone or being connected to R6220 hardwired with your computer? If you tried it doing it with your cell phone app I would suggest you try running the wizard for the R6220 hardwired with your computer and run the internet detection wizard on the router. Did you try that also?
  • > [...] The wired devices are Windows 10 and connect through the
    > just fine. [...]
       "the Nighthawk" means the CM1150V modem?  How many "The wired
    devices" did you connect to the CM1150V modem?  What, exactly, did you
    connect to what, exactly?  (Hint: If a device has different types of
    Ethernet ports, then "connected to device" is not enough detail.)
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    description of "Ethernet ports 1-4", and the following:
          Note  Your cable modem comes with plugs that cover Ethernet ports
                2, 3 and 4. For more information about Ethernet ports 2, 3,
                and 4, visit netgear.com/support/product/CM1150V.
    > [...] even after reading the user's manual.
       Which "the user's manual"?
       Unless your Xfinity service is unusual, you should be able to connect
    exactly _one_ device, the R6220 router WAN/Internet port, to one of the
    Ethernet ports on the CM1150V modem.  Your client devices should be
    connected to the router (LAN Ethernet ports or wireless LAN), not to the
    modem.
  • plemans's avatar
    so try this.
    • Jayesh_P's avatar
      Jayesh_P
      Thank you! Problem solved.
      When I moved all the devices to go through the router, it all worked as designed. I didn't realize what port aggregation was.
