cudaCH
Mar 23, 2021Follower
XAVN2001v2 Accessing Configuration
I have trouble connecting to my XAVN2001v2.
It is connected to the internet router through an Powerlan Adapter.
It provides his own SSID with internet connection perfectly.
But I can't access the configuration in no way.
- With the MacOS application tool it can't be found (via Wifi or direct LAN).
- With miscellaneous URLs (myextwifi.net, mrouterlogin.net, ...) won't load
- Genie App Android also no connection
I wanted to mirror the SSID of the router, which sadly has no WPS button.
Any hints or ideas what to do?
I' want to try everything first before resetting it...
Thanks in advance!
No RepliesBe the first to reply
