Ethan_23's avatar
Ethan_23
Follower
Jan 13, 2018
Xbox not connecting
Saying my DNS isn’t connected to xbox server. My xbox one is the only thing not connecting
  • Hi Ethan_23,
    1. What is the firmware version of your router?
    2. It is possible that you may need to do port forwarding. You may refer to XBOX support for additional details.
    3. The link below may help out once you have additional info.
    https://kb.netgear.com/24290/
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Ethan_23,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Ethan_23,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
