MageHw
May 10, 2017Aspirant
xbox one connection problems
I Cant connect to xbox live with the router
with older routers i used like n300 i had to change something in the firewall settings or lower the firewall setting but on this router im not sure what to do
What is the best configuration for N750 to communicate with xbox one for online purposes
Router is not list the Router is N750 WNDR4300V2
- Well for one I had the router setup correctly. I simply for got that I had my Xbox one console set to a static Ip for a different router I was using, before getting my n750 dual gigabyte router. So once I changed my setting on my Xbox to auto configure ip and auto configure DNs, the Xbox one was able to communicate with the router and connect online.
The ip was set to a range that wasn't in range with the new router.
What ISP service do you hav?
What ISP modem Mfr and Model # do you have?
- MageHwAspirantIt's wired, I contacted support late last night and chatted with a tech that helped me thanks.
How was the problem fixed?
@FURRYNUTZ wrote:How was the problem fixed?
Exactly.
Help other victims by explaining what you had to do and you will win fans and eternal gratitude from other users.
- MageHwAspirantWell for one I had the router setup correctly. I simply for got that I had my Xbox one console set to a static Ip for a different router I was using, before getting my n750 dual gigabyte router. So once I changed my setting on my Xbox to auto configure ip and auto configure DNs, the Xbox one was able to communicate with the router and connect online.
The ip was set to a range that wasn't in range with the new router.- FURRYe38Guru - Experienced User
Thanks for posting. Glad they helped you figure it out.
- MageHwAspirantMe too thanks
:smileywink:
xbox consoles only need auto IP configuration and uPnP enabled on routers. You can set a IP address servation for the console as well ON the router. This works for single game consoles. QoS is dependent upon your ISP speed service and weather or not you have others using band width while your gaming.
- MageHwAspirantThanks the tech provided me with that same information
Enjoy.
