CPNJ
May 16, 2023Tutor
192.168.1.1 keeps redirecting to https://www.routerlogin.net. How do I make it stop?
Firmware version: v1.0.4.122
Router Model: R6700v3
Everytime I try to get to get into my router via 192.168.1.1 I am redirected to routerlogin.net.
How do I get back to getting into my router via 192.168.1.1?
Or how do I get into my router from routerlogin.net?
Or can I undo https just for 192.168.1.1 so that I can get back to using it?
Very strange. I decided to try the same steps again and this time... IT WORKED!
Login pop-up popped up!
There are only two variables that changed:
- Time - it is now several hours later;
- typing in https://192.168.1.1 rather than just 192.168.1.1 (when I typed in just 192.168.1.1, my browser would automatically fill in the https://, so, I'm not exactly sure what the difference is when I do it versus letting my browser do it.)
The mystery is not solved, but the problem seems to be.
Thank you all for staying with me.
- microchip8Masterrouterlogin.net is an URL that points to your router Web GUI. It's the same thing as 192.168.1.1
- CPNJTutor
Thank you for your response.
I am confused. How do I get into my router?
All of the suggestions I've followed on routerlogin.net do not lead me to a place where I can login to my router.
