chris49480's avatar
chris49480
Initiate
Jun 21, 2021
2.4GHz wifi security settings won't save (AC1750 / C6300v2 Modem Router)
I have set up my new Netgear AC1750 Wifi Cable Modem Router (model C6300v2) and it works great except for one problem: the security settings for the 2.4GHz wifi frequency won't save.
The password and WPA2-PSK [AES] security for the 5GHz were applied successfully. When I try to apply the same password and WPA2-PSK [AES] selection to the 2.4GHz frequency, it takes the standard minute or so to apply the changes, and then finishes. The security and password are saved in the 2.4GHz section, but they aren't actually applied. The 2.4GHz frequency remains unsecured and without a password.
How can I get the settings to actually save? FYI, the firmware is the lastest available (V1.03.06). Thanks in advance for any help.
  • plemans's avatar
    have you tried a simple factory reset and reinstall?
