Flash7Gordon
Aug 25, 2016Guide
2.5 ghz password not what Nighthawk admin shows
Hi, Lately my iphone's have been asking for the password if I ask for the 2.5 ghz ssid on my Nighthawk. I go to a PC and look at the password on admin and the password that fails is what I hav...
- Sep 23, 2016
Flash7Gordon, I think the iOS doesn't work the way you think it should? In order to use FORGET the network you MUST be in range of that network. Here is the rub, as far as I know ONLY the SSID and P/W is retained. That is all that is needed to connect. The MAC address is not needed. Some large places have repeaters that use the same SSID and P/W. If it saved the MAC Address it wouldn't connect.
So you were NEVER forgetting the network because you couldn't connect to it. When you FORGET it it just will not AUTOCONNECT to it. That network SSID now goes into the list you can select from.
Again, from what I know, and I could be wrong, this is what is happening.
First 'forget' doesn't delete the data, it just tells iOS not to connect to it. Data is still retained. So in your case it stops trying and then still appears in the list with the wrong P/W. You select it again and it does what it did before, tries to connect. You are in a vicious circle. About all you can do is RESET the network which does wipe all Wifi and SSID data out. However, with one SSID with 2 different P/W's you still have problems again.
Flash7Gordon
Aug 25, 2016Guide
Thanks, just tried "forget" on the iphone and then opening the connection again and no joy. I have some Comcast Wifi ssid's too, but they have really different ssid names. Strange, the 5 ghz is working fine. I'm getting 238meg wifi download on the 5ghz band on the Nighthawk if I stand next to it.
ElaineM
Aug 31, 2016NETGEAR Employee Retired
Try to restart the iPhone and then connect again.
- Flash7GordonAug 31, 2016Guide
Thanks, tried full reset all network setting with a reboot and it didn't work. Also ios 9 isn't really giving me a forget this network option for the one I am having a problem with. Hit the little Blue info icon and all it shows is technical information.
- ElaineMAug 31, 2016NETGEAR Employee Retired
Do you have the latest iOS 9.3.5?
Thanks for the help. Switched to my ipad to see if that made any difference. I just tried a "forget" the problem network, reset all network settings on my ipad and it did have 9.3.5, in fact it just upgraded to it minutes before I tried the network changes. I guess having the same network ssid in two different locations really confuses the part of the iphone that is always remembering the ssid passwords. I will change my ssid in my other location.
