rapacheco3162
Sep 24, 2018Tutor
5G Stopped appearing on my devices as an available network. 5g Light on router is lit.
My R7000 has stopped broadcasting the 5g network on all my 5g capable devices. 5g Light on router is lit solidly ( not blinking) but network is no where to be found to connect to. I noticed this with...
- Sep 25, 2018
Thank you very much!!! Worked like a charm nd I am now back up and running thanks to you!!!!
shadowsports
Sep 24, 2018Hero
Greetings,
In this situation:
Start by logging into the routers admin portal > Basic tab and use the reboot option to gracefully restart the router.
See if this restores the 5Ghz broadcast. To rule out problems with a single device, try looking for the broadcast from more than one computer or mobile device to ensure its not a problem with the device you want to connect instead of the router.
Still seeting the behavior? Next step, use the [Erase] option i nthe routers GUI to reset the router to defaults. After reboot you will be required to set the device up from a default state. The installed FW remains unchanged, but any settings made since update or inital set up are erased.
After set up, again test 5Ghz broadcast.
rapacheco3162
Sep 24, 2018Tutor
I unplugge the router from behind the unit, left unplugged for approx. 30 mins., plugged it back in and the network still doe not show on my other devices but on Netgear genie it states that I hsve 2 devices connected to 5g, but the device doesn't show the 5g networh for me to connect to. By the way, I unplgged because I could not find the rebbot button you suggested
- shadowsportsSep 24, 2018Hero
Greetings,
Reboot button is located on the Advanced tab, not Basic. Typo, my mistake. What you did achieved the same effect. No need to wait in between restarts. Nothing is gained waiting 30 min.
So. The next step. Do not use Genie, use a web browser and log directly into the router.
Log into Router > ADVANCED > Administration > Backup Settings
Press the [Erase] button.... don't worry, its there (grin)
Now perform set up and retest the 5Ghz broadcast.
- rapacheco3162Sep 24, 2018Tutor
did as you suggested, but now I have no wi-fi internet and can't register my router to try to set it up. By the way, I now have both 2.4ghz and 5ghz networks available, just not internetavailable
Greetings,
Sounds like you're almost there. The reset has resolved the wireless issue if both networks are now broadcasting. There is nothing to register. Use the internet Setup wizard in the GUI to detect your internet connection. This is in the top left corner (Navigation Pane).
This should automatically detect your connection. If you need more help? Please tell us who the ISP is, what type of internet connection you susbscibe to and more about the device (modem) in front of your router.
