rapacheco3162
Sep 24, 2018Tutor
5G Stopped appearing on my devices as an available network. 5g Light on router is lit.
My R7000 has stopped broadcasting the 5g network on all my 5g capable devices. 5g Light on router is lit solidly ( not blinking) but network is no where to be found to connect to. I noticed this with...
- Sep 25, 2018
Thank you very much!!! Worked like a charm nd I am now back up and running thanks to you!!!!
shadowsports
Sep 24, 2018Hero
Greetings,
Sounds like you're almost there. The reset has resolved the wireless issue if both networks are now broadcasting. There is nothing to register. Use the internet Setup wizard in the GUI to detect your internet connection. This is in the top left corner (Navigation Pane).
This should automatically detect your connection. If you need more help? Please tell us who the ISP is, what type of internet connection you susbscibe to and more about the device (modem) in front of your router.
rapacheco3162
Sep 25, 2018Tutor
