bschmidt34
Apr 03, 2018Tutor
5GHz band 1 does not work.
Bought this router back in July, my first Netgear. After a few months of operation, I noticed the first of my two 5GHz bands was not showing up. My devices that were configured for it were unable t...
- Apr 15, 2018
You do have a HARDWARE warranty of 1 year which is standard for all routers I think? Call back and say that a 5Ghz signal has failed and you would like an RMA for it... maybe they will do that, but I suspect you'd probably have to PROVE it was broken, and that might mean paying for support which might be refunded if it is broken... can't tell until you call and try.
IrvSp
Apr 15, 2018Master
bschmidt34
May 12, 2018Tutor
Thank you for the kick in the head I needed to just contact them and tell them what I wanted! After reviewing my case history with this router and this specific problem, they agreed to send me RMA info.. They have a pretty fair process for RMA too where I can pay a reasonable fee which covers my shipping and does not require me to send my router until I receive the replacement. I'm happy with the outcome assuming the return/replace process goes as planned.
Thanks again!
