ooVisi's avatar
ooVisi
5GHZ Not Showing on R7800
I noticed that my 5GHZ network wasn’t showing and did a lot of things to try to get it working again to no avail. I rebooted it, I factory reset it, I tried changing the channel. I checked to make sure 5ghz was on, (it was, there’s a green check mark by it in the portal) I checked to make sure the router radio is enabled and nothing still. Any other suggestions?
  • plemans's avatar
    Have you tried disabling smart connect?
    How do you know 5ghz isn't working?
    • ooVisi's avatar
      ooVisi
      Smart connect is off, I checked on multiple devices and 5GHZ doesn’t show up. On the nighthawk mobile app when I manage devices and hit the filter button, it only has 2.4 ghz and wired as an option to be filtered but not 5 ghz
