John167
Apr 09, 2022Follower
7200 doesn’t see my router
My router light will not come on. Device light is green. Help
7200 isn't a full model description. Can you be for detailed on the NG router model your having problems with?
What router are you referring too?What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
What model do you have?
Device/router light implies you have an extender.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
