Swerve83
Aug 25, 2018Apprentice
8TB Hard Drive on Nighthawk X8 R8500
Does the Nighthawk X8 (R8500) support 8TB Hard Drives??????? My 5TB WD My Book is no longer supported it seems on the USB 3.0, but it works on the USB 2.0 port. I am upgrading to a large storage anyway and want to see about making a 8TB work before I get my NAS up and running through my server/switch.
Thanks for any help/advice.
You can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
You may be pushing it with 8TB drives.
For serious networking use Ethernet.
- Swerve83Apprentice
Yah I ran across this link earlier. Figured 8TB would be pushing it. Eventually I will be using a swich with rack holding 5-10 drives, totaling around 36TB.
Thanks for your reply!
As opposed to what, exactly?
