treesRfriends's avatar
Dec 17, 2020
AC1200-R6220 VPN Passthrough
I have contacted my IT professional at work and they could not help me (just said "the router's blocking it"), so I have no other choice than to try and fix myself. I am not a computer whiz, but I can get by with guidance.
-VPN works when connected directly to modem.
-VPN does not work when connected to router but it HAS worked previously when conected to router, then one day stopped.
-I have done the "port forwarding" advice. See attached snip, not sure if I did it correctly.
-I am not sure what VPN software they are using. I know it uses "Wan Miniport (L2TP)". I have included snip of program symbol.
-It is the most recent firmware. I tried installing original firmware (1.0.0.14) and middle of the road (1.1.0.66). Neither allowed VPN to work.
-NAT filtered is "secured". I opened to see if it would fix. It didn't
-VPN Passthrough is enabled for IPSex, PPTP, and L2TP
-Respond to Ping on Internet Port is checked
Please help. I have so much work to do and can't access my work network. Thanks
  • port forwarding snip since I couldn't include two attachments
    • plemans's avatar
      You can always cheat and put the computers IP address in the routers DMZ. This forwards everything to the router. not a safe option but it'd get you up and running. Everything between the work computer and work should be encrypted through the vpn anyway.
      • treesRfriends's avatar
        treesRfriends
        Can you tell me how I can do that. Thank you.
        Any idea on long-term solutions or why the router is doing this?
