kpaw333
Dec 17, 2020Aspirant
AC1750 / R6350 Issues after firmware update
Hey guys,
I'm having a time with my router. It's been mostly fine for a while now. Every once in a while, it loses an internet connection and a simple reboot helps. Then last night happened. I went into the Nighthawk app and saw a firmware update, so I installed the update. Immediately I saw problems. It was slow, then I just completely lost internet 15 minutes after the installation and reboot. Had to unplug everything, then plug back in and turn on. Ok. Then the same thing happened 3 more times today. All before 4pm EST. I have Spectrum and use their modem. It's just weird that this all happened as soon as the firmware updated. I even did a complete factory reset today. Still lost a connection. It doesn't come right back. I have to unplug EVERYTHING. Router, modem - everything. Speeds are still slow, but they have been since more people have been home with COVID. They used to be 100+ Gbps, now down to half that.
I went into all the basic and advanced settings through my computer browser and checked stuff, found some DoS Attacks, but I read those are false positives most of the time on Netgear. They all happened since the last breakdown, so I don't know if they're doing something. It's all strange.
If anyone has had something similar happen, or can offer some feedback, that would be awesome and much appreciated.
I hope you all are doing well, and are safe and happy.
Thank you!
- kpaw333AspirantI can't figure out how to edit the original post on here, but I mentioned 100Gbps. I meant Mbps. 🤦🏻
If it coincided with the firmware update, you can always try downgrading the firmware.
simply download the old firmware and follow the manual update process (from the manual) to install it.
