ATarr's avatar
ATarr
AC1750 not recognizing ethernet signal
Background info: Lost internet a few days ago. Message was "refused to connect", not no internet detected.  Did all the typical troubleshooting.  Powered down and up multiple times for both the modem and router. Refreshed the modem via mobile device-multiuple times.  All lights on modem and router looked like normal operation, indicating proper incoming signal.  Since router is relatively new, replaced modem, problem continued.  Contacted Cox (provider) ran through all troubleshooting and they were stumped.  Sent out a tech yesterday.  Signal coming to house is fine.  changed out inside coax. Changed ethernet cables.  Refreshed, and reprovisioned multiple times and finally get a signal to the modem.  Started by plugging desktop directly into modem.  Each time it was switched over to ethernet connection from modem to router, the modem would reset.  Switched back to old modem and provisioned.  Get signalbut same issue.  Desktop is connected directly to modem, I have working internet.  When I switch the ethernet connection to the router, the light on the router is red, and there is no connection.  It doesn't seem to be the router, as I also bought a brand new AC1750.  So, the same issue exists on two separate AC1750 routers.  Cox tech is stumped,and so is everyone else I have talked to. Please help!
  • ATarr's avatar
    ATarr
    Jun 12, 2020
    Michael,
    Thanks for the response. I appreciate your willingness to help, but I have resolved the issue.  I continued to work on the issue and reset and updated the router and it is now recognizing the signal. I believe the original signal outage caused a glitch in the hardware
  • michaelkenward's avatar
    michaelkenward
    What is this modem? Make and model?
    • ATarr's avatar
      ATarr
      Michael,
        michaelkenward
        This sort of thing can happen when someone restarts a network in the "wrong" order.
        • Turn off and unplug modem.
        • Turn off router and computers.
        • Plug in and turn on modem. Wait 2 minutes for it to connect.
        • Turn on the router and wait 2 minutes for it connect.
        • Turn on computers and rest of network.
        This can also be related to the modem in front of the router. But as you seem to be satisfied that you have fixed the problem, that is a story for another day.
