Darkarise's avatar
Darkarise
AC1750 R6400v2 slow speeds
Hello there I recently bought a surfboard8200 because I was informed my modem wasnt good to get my plans speeds 400 mpbs. Well my wireless speeds stay the same I use the 5g and only get up to 150 mpbs I tested directly into my modem and getting those 400+ speeds, correct me if im wrong but my router is meant to get 400 on the 2.4 and 1300 on the 5. I recently update firmware Version: V1.0.4.106_10.0.80
Anything else to unlock the speeds? The settings on the router are defaulted on the modes there suppose to be. Wanted to ask before I reset it.
Appreciate your time
  • Thanks again for your time I ended up being able to fix the issue by just resetting my router
    • Darkarise's avatar
      Darkarise
      But in summary do I not believe that my router can then push out the speeds it advertised?
      • plemans's avatar
        Its a sad state of how manufactures advertise speeds for wireless.
        Whats more important is actual tested speeds. I usualy recommend smallnetbuilder for speedtest reviews (he's been doing less of it lately).
        here's the review for your device.
        NETGEAR R6400 AC1750 Smart WiFi Router Reviewed - SmallNetBuilder
        If you do look for other solutions, I'd recommend reading a few tested reveiews of the units to see what actual speeds they get.
