tangomango's avatar
tangomango
AC1750 R6700v2 indicator lights don't work right?
Hello Friends,
I connected two external devices via ethernet cable to my ports 3 and 4 (a TV and a Roku player). Both devices seem to pull decent speeds, no delays noticed right now, but the lights on the router are orange/amber and not white. Why is that happening?
Thanks for your help.
  • > [...] the lights on the router are orange/amber and not white. Why is
    > that happening?
       Perhaps for the reason explained in the documentation.  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "LED and button
    descriptions".
          The LED color indicates the speed: white for Gigabit Ethernet
          connections and amber for 100 Mbps or 10 Mbps Ethernet
          connections.
       Additional reading might be beneficial, too.
    > that happening?
    descriptions".
          connections.
      • antinode's avatar
        antinode
        Guru
           You can get the same effect on one port from a device with a gigabit
        interface when it's in a stand-by (sleep, "off", ...) mode.  A typical
        gigabit Ethernet interface in stand-by mode will run at a sub-gigabit
        speed (using less power).  When the device turns active, it will
        negotiate a higher (gigabit) speed.
