Retired_Member's avatar
Retired_Member
Mar 30, 2020
AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
On all of my devices, my AC1750/6400v2 router is no longer visible and is not broadcasting 2.4/5ghz.  This happened spontaneously. I have restarted my devices, the router, and the modem. Help troubleshooting would be appreciated.
  • Retired_Member's avatar
    Retired_Member
    Mar 30, 2020
    That didn't work and your links weren't helpful.  However, I searched these community forums and found out that pressing the Wifi On/Off button solves the problem. I hope my post is helpful to others!
      Retired_Member
      • antinode's avatar
        antinode
        Guru
        > That didn't work [...]
           _What_, exactly, "didn't work"?
        > [...] and your links weren't helpful. [...]
           I'm impressed that you found the link which led directly to the
        suggestion, 'Pay particular attention to the "WiFi On/Off button with
        LED".  Did you press it?' unhelpful, and then revealed "that pressing
        the Wifi On/Off button solves the problem."  Many people couldn't have
        managed that feat.
        > [...] I hope my post is helpful to others!
           Many things are possible.
