Amazingpop247
Jan 08, 2021Follower
AC1900 (C6300BD)
Hello.
I'm not a techno guru at all.
I know I have an AC1900 (C6300BD) NETGEAR router. My understanding is it is dual band.
Currently the 5G is being used for various apparatus at my home.
I'm looking at exterior security cameras that are 2.4G.
Am I able to run both off my router & if so, how do I do that?
Thank you in advance.
Unless you disabled them, they both should be broadcasting and can be used at the same time.
Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for a
topic like "Specify Basic Wireless Settings". Further reading might not
hurt, either.
