PH123
Mar 27, 2021Aspirant
AC1900 C7000v2 Firmware Update
Bought the AC1900 WiFi Cable Moden Router Model C7000v2 in Dec 2020 but just hooked it up this week (3/25/21). Upon setup, received "Firmware Out of Date" message. The Nighthawk app/Routerlogin.net...
michaelkenward
Mar 28, 2021Guru - Experienced User
There's a bug in the Nighthawk app that throws up this message.
You have no control over the firmware on your cable modem/router so it means nothing. It is just annoying and gets in the way.
Netgear knows about this. But don't hold your breath waiting for an update.
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
You might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
For the apps try the section linked above.
