Proteus1
Dec 31, 2025Aspirant
AC1900 Wifi Adapter internet cutting out for a few seconds.
Hi All, I recently built a new PC, and for the most part I haven't had too many issues. I installed my old wifi adapter to my new PC since I figured my AC1900 would have better throughput than t...
Dec 31, 2025Guru - Experienced User
I'd agree with CrimpOn , if this is a new build, there's a good chance the built in is much better as the A7000 is quite old. What motherboard did you buy? Or what built in does it have? I've had a few pretty solid built in wireless cards. Or they have the option to upgrade the chip on the motherboard. Works great.
Proteus1
My motherboard is an aorus elite b850m wifi6e.
Through initial testing with the built in wifi adapter vs the ac1900, I was getting higher speed test results with the ac1900
- plemansDec 31, 2025Guru - Experienced User
Uses the old RTL8852CE from Realtek. Not a horrible card but realtek isn't known for their driver updates. Options.
- Try updating the firmware on the realtek. Directly from realtek. Don't install the ones from gigabit. It "should" be faster than the A7000 by a ways. But that also depends on your router. If the router is the bottleneck, it isn't going to make much difference.What router do you have?
- You also have to keep in mind, the realtek is triband. If you're a bit aways from the router, the 6ghz will drop off quicker in speed. How far from the router and whats in between the router-pc? (walls, what materials, appliances, etc)
- You can replace that wifi card pretty easily and cheaply (probably cheaper than the A7000). The intel AX210 is usually around that 15-20$ if you want to upgrade.
- StephenBDec 31, 2025Guru - Experienced User
So Realtek 8852? It does have some mixed reviews as far as performance goes.
One option would be to replace the wifi card, perhaps with a QCNCM865.
