LWBar's avatar
LWBar
Follower
Oct 07, 2023
AC2000 won't show up to connect
The router ssid won't show up
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Tell us more. Won't show up where?>
    You can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    One thing to note is that AC2000 doesn't tell us much.
    AC2000 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    Look at the label on the device for the model number.
