HeliumB's avatar
HeliumB
Follower
Jan 26, 2022
AC2300 Nighthawk - Where to change NAT type to Open
I couldn't find the Model type in the list, so hopefully this isn't some bootleg model, but in following all of the directions online regarding the routerlogin.net process for changing NAT type, I cannot replicate them. All of them mention a maintenance area I do not see on the attached devices screen, and all of them mention a protocol forwarding I don't see on the attached devices screen. I checked in the advanced menu as well, and cdo not see either of those options. Can someone assist?
  • FURRYe38's avatar
    You can also set NAT Filter from Secure to OPEN under Advanced tab/WAN setup.
  • michaelkenward's avatar
    michaelkenward
    You won't. The list is out of date, but there is no such thing as an AC2300. That's a wifi speed indicator.
    The model number is probably the R7000P, which is in the drop down ;list.
    It is usually better to tell people what you want to achieve rather than what you are doing.
    Why do you want to change the NAT type? You are trying to fix a problem? To get something to work?
    There may be better ways of getting there.
    It can also help to tell people what else is on your network.
