Blues_sLr
Jan 28, 2016Aspirant
AC2350 Nighthawk X4 Smart WiFi Router (USB 3.0 Backwards Compatibility for USB 2.0 Printers
Dear Sir, We are looking forward to buy the AC2350 Nighthawk X4 Smart WiFi Router 802.11ac Dual Band Gigabit Model number version: R7500 , but wanted to know if the USB 3.0 ports are backwards comp...
- Jan 28, 2016
Yes it is.
operator187
Feb 06, 2016Star
Please reconsider your purchase decision and, if set on Netgear equipment, look at models other than the R7500.
The product is "abandonware" at this point.
Blues_sLr
Feb 09, 2016Aspirant
Noted your kind guidance, will u please suggest a best model number considering its WiFi range as in very large homes type, g/n/ac.. Specs same or higher than the above mentioned price range not costlier than the above mentioned. Thanks.
